Help rear door stuck shut
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Vz05.3.6, Sep 28, 2012.
  1. Vz05.3.6
    Vz05.3.6 New Member
    Wollongong
    Vz wagon
    hi just brought my new ride and now the rear door is stuck shut.How can i open the door ive tried pressing the remote and pulling on the door disconecting the battery nothing worked.any ideas on how to open the door would be great.
  2. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
    Does it feel like its grabbing on the striker still or just stuck?
    Tried getting in against from the inside and lifting the lever from inside and giving it a good thump with your shoulder?
  3. MontyVE
    MontyVE Banned
    Sunshine Coast, QLD
    2012 MY12 SV6
    Pull the door trims n **** off n just check if its catching on something.
  4. Pie-VK
    Pie-VK That guy.
    Wollongong, NSW
    Series I VY SS Ute 5.7/M6
    I had a faulty child lock in my old VP that wouldn't let the door open at all...
    I had to punch a hole through the door to get to it though.
  5. uniacidz
    Sideneee
    VE Berlina
    Cant just pull the trims off when you cant access the screws cos its stuck shut
  6. MontyVE
    MontyVE Banned
    Sunshine Coast, QLD
    2012 MY12 SV6
    OH FK haha. Damn, I didnt remember they were on near the clips haha. Sorry brah
  7. Vz05.3.6
    Vz05.3.6 New Member
    Wollongong
    Vz wagon
    Nope its stuck and just got a qoute of $400 to open it and replace the broken part.not happy
  8. uniacidz
    Sideneee
    VE Berlina
    Whats the broken part?
    Might help someone out in the future if it happens to them
  9. Vz05.3.6
    Vz05.3.6 New Member
    Wollongong
    Vz wagon
    not sure yet i aint paying $400 just yet going to try and open it myself and see whats going on.
  10. uniacidz
    Sideneee
    VE Berlina
    Sounds to me like a failed locking mechanism or a wire going to the actuator has failed.
    Haven't done anything like working on stereo or anything like that? Window and speaker work?
    Tried removing the inner handle and pulling the metal inner door locking arm rod?
    Possibly work on it yourself, sacrifice the inner trim and using a dremel tool and patience, mark it out and cut away the inner trim and remove and start fiddling.
    Tried thumping the outside of door near lock and trying to open at same time?
    Sent from my HTC ARIA using Tapatalk II.II.IV
  11. turmoil117
    turmoil117 Donating Member
    Armadale
    Vs berlina
    In my old vn somebody had put the child lock on then snapped off the outer handle... I had to take off the trim inside the car (with the door closed) and disengage the child lock in order to open it
    Sent from my GT-I9100T using Tapatalk 2
  12. Vz05.3.6
    Vz05.3.6 New Member
    Wollongong
    Vz wagon
    i got it opened without breaking anything.i had to unclip the plastic trim covering the seatbelt to get access to the side screws on the doortrim then pop the window switch out and the screw under the door handle.then i just reefed up the door trim it pops off just enough to get your hand in.there is a rod going to the door locking mechanism i yanked on that and pop the door open.found out it was a failed actuator and it was stuck on deadlock.so at least i can stop passing my baby through the window.
  13. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    LOL why not put the baby seat on the side that opened? hahahaha
