marvinstokes
- Nov 14, 2008
- 13
- 1
- 0
- VS
I have just replaced my intake manifold gaskets. Whilst removing the intake manifold I removed a vacuum hose from the rear of the engine from a small electrical component. The hose was fed thru the top of the intake manifold and ended up at the drivers side front going into an emission control device ( I think ).
After reinstalling my intake manifold I reconnected the vacuum hose and it was then that I noticed that the electrical device at the rear of the engine ( close to the fire wall and basically centrally located ) had two points to which a vacuum hose could fit.
A search of the engine compartment could not find any loose vacuum hoses. My question is, should this component have two hoses or one? - If one then which point ( upper or lower ) should have the hose connected to it?
