help shorted something out need urgent help!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by cxcxcxvcvcvc, Apr 26, 2007.
  1. cxcxcxvcvcvc
    cxcxcxvcvcvc Active Member
    The Plains
    VT Commodore
    ok i was running the diagnostic check on my vs calais v6 and accidently put the black wire to the brown wire (situated directly under the black wire) ( instead of black wire to black/white) and now every time i turn my ignition on the fan motor is blowing even after ive taken the wire conector out :(:bang: doesany1 know how to fix it or what ive done?? and yes ive already tried starting the car and turning it off again and ive also tried turning it off via the climate control but it dosent turn off:( and the thing is that when i turn the ignition on the fan blows even though the climate control module is off pleas any help??
  2. Low_VX_Taxi
    Low_VX_Taxi Blanned
    On the couch
    Blundstone boots
    not sure but try disconnecting the battery for 30 seconds at the terminals..... may reset the settings?
  3. Spaced
    Spaced New Member
    1997 VS Commodore Exec
    nah you've stuffed a relay or a fuse. Pull out your fuses and check em. If they're blown you'll know don't know how to check relay's though. I took out a fuse by accident doing the same thing.
    Low_VX_Taxi likes this.
  4. cxcxcxvcvcvc
    The Plains
    VT Commodore
    thats it!
    thanks mate solved the prob the trip computer fuse had blown prob solved cheers!:thumbsup:
  5. Spaced
    Spaced New Member
    lol when you break as much as I do you learn a bit glad I could help.
  6. cxcxcxvcvcvc
    The Plains
    VT Commodore
    problem solved please delete!
