HELP!! Transmission Flare!
W8INL9
Vs Berlina Series 2
So my trans started flaring pretty bad... got told it was the trans that was stuffed so i replaced it with a reconed trans... put that in today and its still flaring pretty bad.. what else could it be ? any ideas ? cause its clearly not the trans its a brand new re built one. any help would be appreciated! ?
Cheers!
acarmody
Donati..Whoa Green
VX Berlina
Low oil pressure. Is the oil topped up to full?
W8INL9
Vs Berlina Series 2
trans fluid or motor oil ? both are fine and filled to where they need to be
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
Check your TPS!
Trikky
Central Coast
VF S2 SV6 Manual
also did you get a new torque converter?
when I rebuilt my auto the guy in the states that I purchased the parts from said to never use a 2nd hand converter on a new box as it wil have crap in it from the old box
anyway if you used your old converter it may have issues with the turbines and it is flaring not the box
W8INL9
Vs Berlina Series 2
will check TPS tomorrow.. and no was a new converter too..thats why i was thinking something 2 do with computer.. or trans module.. or a solenoid i dunno
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
check fault codes?
Sounds like TPS as others have mentioned.
mrenvied8
33
port broughton
1996 black vs 5ltr commodore
Just stating the obvious, if it's not ur tps, check ur trans oil ain't bright red n smells burnt, they could have sold u a dud unfortunately,
