HELP!! V8 Clutch pedal position sensor ECM wiring
ACE4489
ITALIA
VY 5.7
Hello,
going crazy to try to find the ECM pinout for a VY SS with LS1. I swap this engine on a Jeep with manual transmission and big cam. I would connect the Clutch Pedal Position sensor in the ECM to help idle when start but found only auto trans pinout referring to Range Selector PRND pinout.
Do you guys know if there's any CPP pin in the 0411 style ECM?
Thanks in advance
07GTS
Australia
VEGTS BUILT BLOWN E85
clutch switch wont help idle all it is for is so u have to push the clutch in for engine to start, same as auto park/neutral switch
VYCommodore76
47
VY Commy
never needed to push the clutch in to start the VY SS... The only thing it seems to do is disengage cruise control when you depress the clutch pedal.
