Lt dan
- Apr 11, 2013
- 11
- 0
- 1
- Age
- 36
- Location
- Tasmania
- Vt 5.0L
My car is a 2006 ve sv6 6 spd manual.
I have this issue where at low rpm between 1200 and 2000 rpm I get this vibration/rattle when accelerating out of a corner or from a stop. It's only present between this rpm range, it is not present if the car is in neutral and I rev it through the range. When it happens the acceleration feels a little flat too.
I have had it in to Holden and my mechanic both of which are unsure without throwing parts or stripping the car down both of which costs a ridiculous amount.
I have had the timing chain checked as I thought that was the issue. It doesn't affect the car in any other way it just feels like a weird rattle vibration as I accelerate. It sounds like it comes from the engine but I can't check to be sure because as stated before it only makes the sound when the cars under load and not when in neutral. It literally makes this zzzzz zzzzz zzzzz zzzzz noise until it reaches 2000rpm and then it stops.
I hope I can get a bit of direction. Thanks in advance.
