duffysmashrepairs
- Jan 9, 2011
- 2
- 0
- 0
- Location
- Winchelsea, Vic
- 3.8 lt VN Commodore Executive
ok so im pretty sure i know what the problem is, but not how to rectify it
3.8 lt VP calais
heres what happens
key is turned,
starter relay closes circuit to solenoid,
solenoid fires,
pinion gear on starter motor fires out, and makes contact with the flywheel
and then jams up
the starter motor in this car was replaced, because the "mechanic" who looked at it diagnosed than as the problem.
both old and new starters work on bench test (jumper leads and a battery)
while the starters are being bolted up, using the 2 vertical bolts, a gap slowly appears at the bottom of the starter, between the starter, and the housing around the flywheel. when fully tightened, the gap measures about half an inch.
at first i thought there may be a problem with amps, and the starter not getting enough power. three new batterys failed to make a difference, as did cleaning the metal that earths the starter, and the contact that provides it with power.
even with jumper leads directly connected to starter, the same problem occurs (bypassing the motors earth)
my theory is that, at some point the starter has been hit from underneath, or over many start cycles, and that has bent the starter up somewhat, causing the gap at the bottom, and causing the pinion gear to misalign with the flywheel. the only problem is, there is no gap at the top, and the bolts appear to go into cast, which i really dont want to hit with a hammer.
after looking at my vn commodore (3.8 lt executive) it has another bolt, that this vp does not have
as well as the two vertical bolts, it has a single horizontal bolt, that holds the bottom of the starter to the housing around the flywheel.
if this vp had the same bolt, i dont think there would be a problem, but im not about to drill holes and tap threads.
anyone have any suggestions? the owner of this car wishes to burn it...
3.8 lt VP calais
heres what happens
key is turned,
solenoid fires,
and then jams up
