VZ57SSZ
- Jun 21, 2005
- 614
- 3
- 18
- Location
- Central Coast
- MY16 VF Series II SSV
HI guys
I made a previous post Here
I looked at the BCM today and it says 885 Lux
I thought VR only used low mid or hi
What is a lux bcm and what is difference can I just use Hi if not can i disable my immobilizer since i think they that may be the cause of the problem.
Also does the 885 BCM have the theft deteriorate module build in ?
Thanks
My car sometimes will not start just cranks, I then turn it off and press the remote it then starts, also sometimes when driving the car cuts out and sometimes will not start again until the remote is pressed.
Also a few months back when I tried to lock the car with the remote the blinkers flashed locks went down then came back up again almost straight away, I then had to lock with the key.
Before referring me to checking codes which I will do as soon as I find a paper clip or spare wire, could the BCM be responsible and how much would it cost to replace on a VRII Berlina
Thanks
