HELP!! vs miss when booting it
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by TOBSTA, Aug 24, 2006.
  1. TOBSTA
    TOBSTA Guest
    my 1997 vs 5spd v6 ute has a miss when i shift gears and put my foot down, is this spark plugs? coilpacks? please help as i want to get this problem sorted a.s.a.p
  2. ChRiDDa
    ChRiDDa Active Member
    N/A
    VE SS-Z Sportwagon
    either a lead or a plug.. had this problem quite a few times with the old mans VS V6 where it would miss under load
    turns out one of the plugs was crook (brand new too)
  3. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    Yeah definately a buggered lead. Had exactly the same problem on the old mans VS V6.
  4. TOBSTA
    TOBSTA Guest
    alrite cool. what plugs and leads do you guys recommend and do you reckon it'll improve my fuel economy
  5. Harvs82
    Glen Waverley VIC
    I run Bosch leads on my VS Berlina, I think they are 8mm. You need to make sure that you get a set with the heatshields on them to protect the lead from the exhaust manifold.
    I just run the standard NGK plugs, had Iridium ones in there and found it didn't make any difference.
    Part number for the NGK plugs is: BPR6EFS-15 1.5mm Gap
    Part number for the leads (complete set) is: B6025i (with heatshields).
    Hope this helps!
  6. TOBSTA
    TOBSTA Guest
    alrite got brand new bosch super plugs, and brand new top gun leads, and its STILL missing..aaahh what can i check next, coilpacks? distributer? come on please help, it misses between 1200 and 2000 rpm mostly and is rough on idle
  7. Harvs82
    Glen Waverley VIC
    Maybe check the DFI module and Coil packs, check the resistance on the coil packs, both for primary and secondary figures...
  8. TOBSTA
    TOBSTA Guest
    how do i check the DFI module!!!
  9. TOBSTA
    TOBSTA Guest
    just an update, those top gun leads i put in were ****ED within 10mins so ive just replaced them with the GM geniune ones.... such a pain in the arse!!!
  10. totq
    totq New Member
    Forest Lake Brisbane
    VR Calais 3.8, Raptor S/C
    Tobsta,
    is it still missing?
    i would have said plugs or leads too but you've try those, could be something as simple as a clogged fuel filter too, happens when you boot it is when it needs fuel most.
    i had this prob in vr calais too, and yes, i tried top guns leads and bosch super 4's too and they are not as good as genuine leads and ngk plugs.
    at least the fuel filter is cheap to eliminate as a possible problem.
