Help with catch can install
Mattricho
VF SSV my15
Hi all I’m looking at fitting a ProVent 200 catch can to my 2015 ssv (series1). Now, my question is how do I hook it up?
As far as I can tell I just need to join to this pipe that runs from the right valve cover and joins up at the intake.
My other question is what about the left valve cover?
Do the left and right sides join somewhere or do I need a Y or T piece??
Everything on the net is about LS3 engines and all you need to do is remove a little U shaped pipe and that’s it because the LS3 has a different valley plate then the L77 engines.
Mattricho
VF SSV my15
Bump
Anyone got any info from me
villn808
You got it right, and left one goes to clean air breather.
villn808
Here's a photo of mine when it still had all the AFM hardware like yours.
Pollushon
Boost gives me a bar....
VY SS
The principle is all three breathers go to the catch can inlet. Outlet goes to the TB. You just have to work out the bit in the middle.
villn808
Not quite right, Drivers side valve cover breather requires fresh air as its a vaccum.
dgp
VF II SSV Redline
I have this pic from another forum (thanks Micks), you would route your stale air from passenger side head to catch can from where it says it is capped with no AFM hardware.
villn808
He has L77, it has AFM hardware.
dgp
VF II SSV Redline
Yes I know Villn, that's why I wrote in to plumb from the capped passenger head breather.
I thought it was a good visual diagram.
