Help with Ecotec parts
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by HIROLLA, Nov 7, 2006.
  1. HIROLLA
    HIROLLA Member
    vic
    VS SIII CAPRICE
    Hi guys
    How on earth do i take the plenum off the ecotec? ive taken the top plate off and undone the bolts in there but theres bolts under the plenum?? How do i get to them i need help as im painting/chroming many engine components.
    Cheers Guys :)
  2. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    After the bolts IN the plenum have been taken out, simply pull up hard on the plenum. All thats holding it on now are the injectors.
    Be carefull when pulling it up though, otherwise you may damage the bottom plastic nozzle on an injector.
  3. HIROLLA
    HIROLLA Member
    vic
    VS SIII CAPRICE
    Thanks IBLOWN much appreciated. I think i might disconnect the injectors then.
    Btw awesome ride im actually in the process of building a bigger motor.
  4. IBLOWN
    No probs!
    Yes disconnect the injector electrical connections, but like i said be careful with the bottom ends of the injectors that plug into the valley cover. They are easy to crack or chip the plastic nozzles.
