Help with knock sensor code
Cannman07
Wynyard, Tasmania
VX Commodore S
Hey, I've been getting a check engine light coming on but when the car is turned off and restarted it's gone. the code is P0327-left knock sensor circuit fault. I've read most of the posts here but haven't found a solution. New knock sensors, new O2 sensors, all wiring is fine, fuel filter and fuel pump only 6 months old. It seems to happen under load at low revs. I've added a readout from my scan tool to see if someone can pick something up. My car is a series II VX S V6 factory manual. Thanks.
  • VX Commodore Scanzilla 16-5-22.pdf
lout
60
Langwarrin Victoria
what brand O2 sensors
2.19 litres fuel per hour is very high
looks like fuel trims are trying to reduce fuel
doesnt add up
BlackVXGTS
Melbourne, SE
The attached from the Holden VT/VX Service manual may help you. Note the statements that a faulty PCM is a possible cause.
  • DTC P0327 V6 PCM - LEFT HAND KNOCK SENSOR CIRCUIT FAULT.pdf
Cannman07
Wynyard, Tasmania
VX Commodore S
Thanks for the attachment, I'll see if there's anything there that can help me. The PCM has already been replaced.
