:bang:hi ,i have a vs which has just had 355 stroker put in it,now i have brought a crane cam 286 ,and rollmaster 9 key way with double row chain,now iv put the cam in as diagram shows,,how ever the bottom sprocket is on -2 ,when it is on TDC ,number one cylinder and number 4 cylinder are at top,now if a was to move it from that position to get 0 or + 2 ,but keep the same 9 links in between,i would just move the crank sprocket and the cam spocket just stay s on the cam as it is ?????????????,now just wondering is there anyone out there that has done the same thing to a 355 stroker and can any one let me know if thats is the right way im going about it ,any HELP would be GREAT thanks.:bang::wax:
Dude You need to Dial it in.. You can buy a book and a Disc which is what you need unless you know someone who has done it before.. To hard to explain on here..
