Hey does anybody know how to get at the key illumination light on the VT i have no idea, can you just put a screw driver between the two halves of the steering wheel column? Cheers also what globe does it take?
that's the easiest to replace with your finger under the lower half of the steering surround , where the key barrel is, there is a hole where you can push it out you just then replace the globe
