help with sat nav
michael.meli
ve ssv
hi all
i have a 07 ssv that does not have sat nav. the factory stereo has the button but when pressed it says somthing along the lines of full nav not avalible, so i assume its not fitted. does any one know the difference bewtween my entertainment unit and one with nav, and what i have to do to fit or make this function work
thanks
mov
VE SS V IGNITION
Err...buy Sat Nav from Holden.?....Set you back 2-3 thousand.
Johnsy
C/Town
VF SS Wagon & VF SV6 Ute
You can screw them down to $1600 fitted in these so called tough times.....
The only thing that changes is the unit installed in your glove box and the right steering wheel button that used to say mute/bluetooth will now say NAV/Bluetooth... and your right wheel on the steering wheel will now become the mute when pressed in .
