Help with the VP please.
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by adam69, Feb 25, 2007.
  1. adam69
    adam69 Banned
    VT Clubby
    Hi all,i got a VP on the road a few months ago and has been going great but is starting to play up a bit.Can you help?
    Its a VP2 V6 dual fuel and has a VN ser 1 memcal.Now the engine light has been coming on and off,it is loosing coolant after parked(even after replacing rad cap),missus says it has made some sort of squeeling noise on start up(has new belt)but not always,only did it the other day.Now i know its has a head gasket problem as im getting some sludge on the rubber on the radiator cap.
    Any ideas?
  2. Cobez
    Cobez LS-EXUAL
    2004 S2 VY SS Ute
    well theres a good chance the engine light is going on and off from the chip...........it did in my vp..........as for the coolant check your radiator hoses connections make sure they are done up tight or there just may be a split in the hosing or a leak somewhere (obviously).............
  3. Burt_vn
    Burt_vn Back in the game
    Gold Coast
    VG V8 5spd, 400hp 5spd soarer, vq stato
    Well you just said you have a head gasket problem, I suggest your main loss of coolant will be through this. The engine light im not too sure of but I'd say being aware of a blown head gasket and not fixing it is your best bet for future problems. So, go fix it!
  4. adam69
    adam69 Banned
    VT Clubby
    Its loosing the fluid from the bottle overflow hose.
  5. Vt-Brrrlina
    Vt-Brrrlina vp bt1 gts replica
    Perth, Western Aust
    vp bt1 5.0ltr full GTS kit
    from what i remember of my old vp dual fuel the o2 sensor gets fried easy this could be the engine light problem
  6. adam69
    adam69 Banned
    VT Clubby
    Thankyou,ill check it out.Ive never seen it come on but SHE said she has seen it.Its very inconsistant.Does it come on with high engine temp?
  7. Matt_vp
    Matt_vp Donating Member
    Gladstone Qld
    vy lumina v6 A4
    have u checked the fault codes?
    Matt
  8. adam69
    adam69 Banned
    VT Clubby
    Havnt checked code but drove it myself and found out whats up i think.Noise on some start up sounds like the ignition is staying on after starting(like you havnt turned the key back)and stopped when the temp creeped up popped the bonnet and found coolant pissing out from behind where the coil pack is.I couldnt see in there but i dont think there are any hoses in that area appart from the bottom rad hose and its much higher than that.My guess is that its leaking from the head where it meets the block.
  9. adam69
    adam69 Banned
    VT Clubby
    found the water leak,it is from the bottom rad hose,was too hot before to have a good look but have now found it hiding behind a wiring loom.
