HELP with Transmission Temperature PID 2009 Calais V 3.6 5 speed
CrustyDragonSlayer
121
Hobart
VE Calais V Sportswagon MY9.5
Hi;
I have been playing around with Torque and Dash Command trying to find the transmission temperature on my VE listed in the title. I also purchased the extra GM pack for 2009 vehicles also for dash Command.
I'm using an OBDLink MX + Bluetooth adapter which can use the GM SWCAN.
I have tried the four different mode 22 PIDS for GMs Header 7E2 or auto for 221940, PID 221949 and another I can't remember.
None of which provide the transmission temperature. The vehicle has trans temp in engineering mode and has a sensor in the gearbox.
Is it just not available for my vehicle or is there another way or command that I can used to make a custom gauge PID?
Any help appreciated!
Thanks Dan
DAJOKER
Adelaide, SA
VE SV6 II Wagon
I'm the same. I use CarScanner, but the same PID' s you've mentioned, and nothing.
But on a scan tool, I can see the ATT, so it's there, just can't be read for some reason.
CrustyDragonSlayer
121
Hobart
Frustrating. The more I look into it's looking line they don't use the OBD mode 22 PIDs for that and that they use their own propriety code to send that information.
I think to do it involves scanning the canbus and finding the information that way. I figured out how to connect to the OBD port using the telnet server on Torqueand I think I've figured out the commands and how to scan the canbus for the transmission control module signals and see if I can find the mode and pid that way.
If I find it I might be able to use it to create a custom PID, fingers crossed. If I do I'll post how to set it up.
