help!
Reevesy08
98 VT Commodore
na got the cables from car audio shop id neva seen cables like it
na it usually goes up automaticly wen i changed from cd to fm
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
the wire in the rca's you think is earth is probably the remote wire to turn on the sub ive seen them like that before but i allways use a seperate wire
spirto
VQ Caprice II
for the antenna to only go up when ur listening to the radio, the deck has to have that feature built in, to test this do this.
1. turn on deck
2. play radio
3. test remote wire, check with test light if power on great.
4. change to cd, if light goes off, then it will let you drop the antenna when playing cd.
if it doesn't you can always wire your own switch to cut the antenna when ur not needing it.
cheers.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
theres a seperate blue wire for antenna not the remote wire they are 2 different wires i doubt the rem wire will work an aerial to well
spirto
VQ Caprice II
ok my bad, I call the antenna wire the remote wire, thought they were the same thing.
same principle, for my testing just check the antenna wire for power when in cd mode.
StoneX
44
Hastings
VE Calais-V 6.0L
the head unit is is pioneer
Pioneer's have a common problem... They have an internal fuse in the RCA circuit which blows quite easily and then causes engine noise through amplifiers. This has most likely happened.
camstatic
I'm back babeh.
Regional SA
VZ SS
Also Pioneer headunits are notorious for putting up the antenna even when they don't need it. :(
StoneX
44
Hastings
VE Calais-V 6.0L
Buy a brand with both an antenna wire and a amplifier wire then OR get a tech to add an antenna wire :)
