helpp please amp setup
Discussion in 'Car Audio' started by Haydz, Nov 19, 2007.
  1. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    hi i have a jvc headunit and i just acquired two 12 inch subs and a boss audio 1200 watt 4 channel amp what is the best and easiest way to hook it all up thanks
  2. Haydz
    VS UTE LS1 T56
    do i need to get an amp wiring kit ?? anyone have any instructions?
  3. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
    yes you will need a wiring kit. I once found an easy guide for basic installation.. will have a look for it.
  4. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
  5. Haydz
    VS UTE LS1 T56
    thanks heaps one question though how do i bridge the amp do i just connect a cable between the two positive and negative ports i want to bridge? thanks
  6. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
    depends on the model amp, eg. you usually use the + of the left channel and - of the right channel. but seeing its a 4 channel, you should try find out some info on the amp. might even be written near the terminals if lucky.
  7. Haydz
    VS UTE LS1 T56
    and how much roughly speaking should i pay for one of the wiring kits?
  8. garfa
    garfa New Member
    SE Victoria
    VY SS
    depends on the size of the power wire and number of RCA cables.
  9. Haydz
    VS UTE LS1 T56
    went to strathfield today and they have sony one for 60 bucks think i might get it
  10. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
    what was included in the sony kit?
  11. Haydz
    VS UTE LS1 T56
    umm everything you need to install an amp so power cord, rca cable that other one lol umm clips thats about it im going to get it tomorrow so if your interested i can post pictures
    before i install it
  12. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
  13. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
    yeah, I ment tho as in what gauge cable, how many RCA's .etc
  14. Haydz
    VS UTE LS1 T56
    not sure about all the specs but i will have another look i figured that a kit like that on ebay will still be around the 30-40 dollar mark including postage so i may as well go with sony as they are a known brand i will also be able to change the amp but the wiring will stay the same if you get me i dont want to wire the car twice kinda pointless if you ak me.. was thinking of writing a how to on installing an amp tomorrow afternoon
  15. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
    if the sony kit is 4 gauge or larger (smaller number) then get that. otherwise, any oxygen free cable (OFC) like the one on ebay will be fine.
  16. Haydz
    VS UTE LS1 T56
    well i ended up with the sony kit as it was down from 90 to 60 has been quite good it is 8 gauge cable and has 3 rca cords for 4 chanels so im pretty happy have it all installled almost that and my rampage 200watt x2 amp lol
  17. azzfox
    azzfox Braaap.
    Yarra Valley, VIC
    VE SS-V
    Boss and Ramage = top quality choices there :whistling ah well if it works for you..
    just hope 8 gauge is enough.. if not, hopfully the fuse blows before anything else does :p
  18. Haydz
    VS UTE LS1 T56
    well it is my first setup and all up it cost me 100 dollars plus it only has to last till christmas so to tell you the truth im not bothered when im done hook up the amp into the ute or something
