helppppp me
MAC-VN
vn90
ok guys see the black wire from the switch n
and the 2 other black wires from were the lights come
well i only have one wire from the box this the wire thats ment to hung outaa the wries from lights anit there
so i put the black wires on the - side of battery n the red wireon the +
and i put the black wires to the lights on the light panel tabs
and the white wires on the wires coming from the globes
then i clicked to turn it on ANFD NOTHING so i tryed puting black on the globes n white on the panel and nothing
and i ment to have the black earth wires on the -side battery
greenacc
Searching for the billion
VE Berlina
your description has me confused , but i'd say yes, the earth on a commo is negative.
The negative battery terminal is connected to the chassis , so any other wires you earth to the chasis will be -ve also.
Hope this helps ! ?
MAC-VN
vn90
thn why isnt it working
MAC-VN
vn90
well ther to earth wires or watever the ones that are in red cicule are on the other battery tremanill next to the +
or shud they be just bolts to the car or sumfin
MAC-VN
vn90
iight ill explain wat i done for you guys i swear im stupid
theres a metal tab on the light plan near were globes goes into
and theres a wire from the globe with a tab
so i put the black wire for the lights on the tab on the light panel
then the white wire on the globes wire
so then in the pic i put the red wire with fuse on the battery n left the left over blackwires hunging n turned to turn them on to see if they work befor i put all in
and they didnt work so i put the black wires on the - battery tremanal and still didnt work so this is were im stuck i hope my typing is ok
SweetWagon
booosted
Springwood NSW
VS Berlina Wagon Supercharged
You need to hook up the blue wire to high beams or a positive source, which will allow the relay to activate
caaf
Melb, Vic
www.aurfscan.com.au
VYII Equipe S/wagon V6
Wow you really gave my eyes a good run around there trying to understand a single word..
Its a simply relay config.
Red = to the battery (constant 12v active)
black = to the body of the car (negative, ground, earth, negative battery return)
blue = high beam (switched 12v active @ headlamp)
If you want to see if there working before you connect to the existing cars loom, simply put a constant 12v+ on the blue cable. After your test you will need to control the lights via the high beam active just so you aren't fluffing about looking for a switch to turn off when there's on coming traffic plus you may find you have ADR's to follow )
