Hemi
UNDERCOVER HQ
HOT 202
townsville
VN BERLINA 202
WILL THE FORD 250 CRANK SHAFT FIT IN TO THE 186 202 BLOCK IF SO WHAT NEEDS TO BE DONE.CHEERS.:idea3:
glenn l
ve sv6
go onto gmh-torana.com there is some good info in there about it.
GenReaper
Donating Member
Radelaide
www.AusHeli.com
VY SS Series II Wagon
Pretty sure they use a Ford 221 crank cut the snout off and weld a 202 snout back on it.
Different pistons with pin heights shorter to compensate for stroke.
Better off to use a longer custom rod and a shorter piston pin height piston to try to correct the rod/stroke ratio.
Cause the usual setup has a tendancy to poke rods out the sides of the block.
