Heron SSV
- Jun 13, 2012
- 379
- 68
- 28
- Location
- Central Coast
- 2009 NT Pajero Exceed, 1984 VK SL
Updates:
Stripped the front end (suspension, k frame, steering rack etc.), cleaned up the bay and its now in primer ready to be painted white to match the rest of the car. Gave it a wash as well, paint came up pretty good, just needs a good cut and polish once its close to being on the road.
Got a heap of parts - VT brakes (master cylinder, discs and calipers), VT hub adaptors, VS booster, VS fuel tank, new alloy radiator and thermo, VS k frame, VL manual rack and shaft, 4 inch reverse cowl (drunken ebay purchase #1), SuperPro bush kit for the front end including strut tops, B&M Stealth Pro Ratchet shifter (drunken ebay purchase #2), CAE conversion gear (tri-y headers, starter relocation kit, trans x member and mount, engine mounts, fuel pump and regulator, flex plate, new engine harness & computer), TH400 box and converter ordered today, probably other stuff I've forgotten.
Need to get the front suspension pulled apart to get cleaned and painted, new bushes put in and reassembled so I can trial fit the motor and check clearances.
