I was thinking of a way to put the VK in my garage so can strip it right down and not worry about it being out in the weather. My problem is I have a double garage and need to keep my Pajero in there as well, and I didn't think there was any point having the VK in there as well but not being able to get to one side that well as it would be up against one wall. Those speed jack things you put under the wheels that jack the car up and let you slide the car around would be ideal, but they're close to 500 bucks for four of them. Then I thought about getting some box tube steel, 50x50, and basically fabricating four squares that each tyre will sit in, then bolting a heavy duty castor wheel to each corner. This will let me drag it into the middle when I'm working on it, and push it back when I'm done. I have a mate who can get the steel, so I'm only really up for the wheels.
What do you guys think? Would it work? My driveway slopes away from the front of the garage so I can't push it in and out when I work on it.
