Hey Guys,
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by jarydvp, Jul 28, 2008.
  1. jarydvp
    jarydvp New Member
    vp executive
    Hey There i just bourght myself a new vp executive in mint condiction i bought it of a old laddy who never did over 50k on it i was wondering if anyone has some good tips on what type of cannon i should put on it and what type of rims should go on it also i was wondering if anyone knows the legal lowering limit i got told i was 100mm from the lowest part of your car is that right?
    thanks guys :yeah:
  2. georgeonboost
    georgeonboost clutch it!
    Melb SE Suburbs
    slammed VP EXEC
    congrats on the good buy.
    1. don't put a cannon on a commodore, they are for jap cars/ricers. Go for a 2.5" catback exhaust with twin tips or something.
    2. rims, they are purely your choice. i have calais international rims on my VP and i quite like the look of them. (check it out in the my ride section)
    3. as for lowering, it really depends on your states regulations. here in vic you are allowed 100mm from the lowest point of the vehicle and i think thats with a full tank of petrol and a car load but im not entirely sure on that.
    hope this helps.
    -George
  3. DavoVP
    DavoVP New Member
    Well man, if you want to put a cannon on a commodore, i suggest you donate you vp to me, ill be more then happy to give you an adress where you can drop it of, and you go and buy your self a nice honda civic or sky line.
  4. Morton
    Morton For external use only
    Fairstar the Funship
    1) If you put a cannon on it, I will track you down and steal your letterbox
    2) Try to stick with second hand wheels from other models of Commodore/HSV/Calais etc
    3) 100mm from the lowest point when fully loaded. Superlows are a good height.
  5. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    The 100mm rule is without a load (passengers) but wit all fluids (so whatever fuel it has in it, full tank would be the best time to measure)
    Pretty sure all the states still use the eyebrow height (although even if your car meets eyebrow heights, it may still be lower than 100mm)
    VP is 320mm for the front, and 290mm for the rear. Measured from the middle of the hub to the bottom of the wheel arch.
  6. Philthy
    Philthy That dent guy
    3.0R Liberty, XC Falcon
    Get a 2.5in catback exhaust if you are after a better sound. A cannon will sound crap, and generally spoil the look of an otherwise nice car.
    The rims are a personal decision. Have a look through the MY RIDE section and see what people have done to give you an idea of what looks good. Rims often come up cheap on this forum.
    In Vic the lowest you can go is 100mm from the lowest point in the car, but if you haven't driven a lowered car before I wouldn't be dropping it on its guts right away because you might find that it's too much of a pain not being able to go over speed bumps or into driveways. Superlows shouldn't be too low, but will still look good
  7. Fatvl308
    Fatvl308 Fatvl308
    vl executive 308
    no cannon 2 and a half inch cat back mandrell bent system.100mm from lowest point rims granges look nice or simmons
  8. taskmaster
    taskmaster New Member
    goonellabah, NSW
    2000 VT series 2
    bugger that ill come to you and yeah cannon on anything but a rice is just crap
    i gave a connon to a mate of mine to put on his little brothers pulsar and he end up putting it on his vt he is the only one who thinks its cool
