hi i want to know if i can use my 5sp in my vk also wenn i put a 5ltr in it
jasonvzss
47
bluemountains
vz ss
my car is currently a 3.3 6cyl carby with a 5sp. i want to know if and wen i put a 253/308 in it if i can still use the gearbox/tailshaft etc cheers jas
Jonno
Vic,
i dont think u can... but im not actually sure
DerekP
VH SL/E 5.0
Depends on how you intend driving it. Is it a stock 5spd?
You may need an adapter plate and different length tailshaft, but like jonoo not %100.
SL/ENUT
The SL/E Fanatic!
39
Burnie, Tasmania
VB SL/E 5L
Nupe, the torque of the V8 would kill it very quick, even driving like an old man/woman.
VK SL 3800
VK SL 5spd
They dont bolt up for starters and they are renowned for there weakness and being able to be broken by a 202.
jasonvzss
47
bluemountains
vz ss
i know its not going to bolt up this aint my 1st project is in holdens i fiq i`d need a adapter plate or something keep the info coming guys :)
VK SL 3800
VK SL 5spd
Dont even consider using it, they didnt release it with the EFI 202 because that would break it in no time. Find a T5 or M21 or something. Using it will only end in tears........
RazzaCaine
Long Gone Now
even an m20/21 will have issues. mine is a bit tempremental and i drive my vb like an old man 90% of the time. reverse gear crunches every other go and 3rd crunches about 25% of the time. id suggest getting a falcon t5 or a supra 5 speed if you have the money
VK SL 3800
VK SL 5spd
Yours sounds like she could do with a rebuild or try some different oil, pretty much any gearbox will crunch into reverse.
