High Beams Blowing!!!
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Keesh, Jan 23, 2007.
  1. Keesh
    Keesh GM Parts tech. support
    HSV WL GRANGE LS2 , VQ 5L Caprice
    ok heres the story..
    i went to flick the high beams on and pop goes the fuse.. now i replaced the fuse and again pop.. the guys at work came to the conclusion that there was a short in the stalk.. vn stalk are no longer made so i attached a new vt style one thinking that would solve my problem and when i replaces the fuse and turned on the high beams POP.. anyone no where it could be shorting and why?
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    tried changing the relay over? the wiring in th fuse box could be damaged or the actual lights themselves might not be earthing thru the light housing
  3. Keesh
    relay ey.. im running out of 25amp fuses haha.. it might be the relay.. i was fiddling with it cause i took my starter reelay out so no one could pinch the car.. ill have a look
  4. Boonz
    green 355 VG ute
    also check the wiring under the relays. therse a little tab you push down and the whole relay holder comes out
  5. Keesh
    no where else is the really.. if the globes blown will it short?
