High Compression Pistons
Whiteford88
38PONT
Tamworth, NSW
WH Statesman 5.7L
Hey guys, I was just wondering, the compression ratio of the S1 3800 V6 seems pretty low, how much would the engine benifet from a higher compression ratio say 9.5:1? I'm talking, torque, horsepower ect, and if high comp pistons would be the way to go or shaving the head or changing the head ext.
Thanks in advance :) Craig.
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
there would be some gain, however it wouldn't be a huge gain or possibly the worth the $$$ spent. would also need a retune to suit.
to raise the compression as much as you've suggested would require changing the pistons
acarmody
Donati..Whoa Green
VX Berlina
A nice big cam AND raised compression on the other hand......
Immortality
Staff member
Sth Auck, NZ
it certainly would be a interesting experiment and i'd be intrigued by the results. i'd be keen to see what the old buick could do with the same CR and cam specs as the ecotec
Whiteford88
38PONT
Tamworth, NSW
WH Statesman 5.7L
Indeed I would also be intrigued by the results.
High Compression Pistons and a CAM, and re-tune.. would hopefully put out an extra 20kw at the wheels, or atleast 30 at the crank? or am I being to generous? lol.
NPreston
Victoria Point
VC
Well if you are going to fit high compression pistons you will almost certainly need to deck the block to obtain correct height. My 3.8 Buick with High compression pistons, 10.5:1, decked block, milled heads, cam, lightened flywheel, 70mm throttle body, bigger injectors and serious head work puts out 161 kw at the wheels. All in a stripped out VC.
Whiteford88
38PONT
Tamworth, NSW
WH Statesman 5.7L
And how much did that all cost? Seems like a lot of work for only 40 extra kilowatts at the wheel.
