High Idling
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mal62, Jul 17, 2006.
  1. mal62
    mal62 VR Going Wild
    Townsville Nth Qld
    VR 5 Speed Wagon & VS Auto Wagon & 98 VS Statesman
    I have a VR V6 and its idling at approx 2000rpm. it used to idle ok but has steadily been getting higher, any ideas as to what could be the problem?
  2. Berlinarator
    Berlinarator New Member
    VZ SS-Z
    is it auto or manual?
  3. mal62
    mal62 VR Going Wild
    Townsville Nth Qld
    it came out of the factory as an auto but have since converted it to a manual still using the auto loom and i had the chip reprogrammed
  4. The Idle Air Control valve is bolted to the throttle body and controls idle speed and stability, The throttle butterfly and the IAC bypass ports can clog with carbon which can directly affect idle control and idle speed, so u should pull apart ur throtle body and give it a good cleaning.
  5. holden007
    holden007 VRII
    Subaru Liberty
    Check the throttle positioning sensor while your having a look at the IAC for defects.
