high knock count causes?
robkeith
south australia
Hilux LN110R with Vx ecotec using VP11 electrics
Hi brains trust,
i am getting high knock counts with the VP V6 ecu.
knock counts are a steady 195 - 200 across ALL RPM and Load ranges, including at idle and overrun?
This then causes the ECU to give a constant 12 deg advance reduction
any suggestions re what may be causing this greatly appreciated
Immortality
Staff member
Sth Auck, NZ
Check the connection to the knock sensor.
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
It does sound like it is a sensor issue as it’s not really likely that it would knock constantly at all operating speeds and rpms.
gtrboyy
vt ss & lc gtr
You trying to tune it or fault finding? Modified?
Check or replace knock sensor & wiring if fault finding.
If modified or tuning probably mechanical noise...time to research & learn.Lots of good info plus memcal tunes already up on delcohacking forum.
  • Like
Reactions: Lex
robkeith
south australia
trouble shooting, i also believe its an extraneous issue. a constant value makes me think its electrical? counts are good until above 75 deg coolant temp (which makes sense as input from sensors is disregarded until then) different sensors have been
tried same result. no error codes coming up
ecotec with vp style sensors with the vp ecu. all sensors and even the loom have been changed out, same result?
motor is stock except for extractors
robkeith
south australia
connection is good, (new plug)
continuity from plug to ecu tests OK
New Knock sensor NO difference.
shows constant ~ 200 knock count and 12 deg retard (tunerpro 5)
disconnect sensor 6 deg retard AND constant 200 knock count!!
me thinks it is electrical interference!! but where??
have tried 2 ECU's
2 looms.
new CTS and O2 sensors as well??
any ideas?
gtrboyy
vt ss & lc gtr
Mechanical noise
Pulsing fuel lines
Fuel dampeners fubar'd
