High octane fuel and the truth
Ozzie
JCCC Warrnambool
Warrnambool
Ozzie'z Supercharged VY Calais
Yeah. I am no expert but I think the later commodores can run better on higher octane fuel as they can adjust on the fly with the knock sensors.
lol nah holdens too cheap for that..
Not sure bout VE's but I know VY VZ were tuned to run 91.
Though the more exotic holdens like monaros and clubbys ect.. were tuned to run the higher octane.
BowTie
Jindabyne
Vr vt
They are quite bold sweeping claims to make without giving the tiniest hint as to your qualifications or experience.
You speak like a wannabe petrochemical engineer whose knowledge is so far above ours that it would be demeaning to have to explain yourself.
I call bullshit on your hypothesis.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
I suppose grandmas can't afford 98 or 95 any way. Good point.
Ozzie
JCCC Warrnambool
Warrnambool
Criticism will only get you an infraction.
Dont need claims. Ask any good mechanic.
sik_dose
Hybrids. Cars for fools.
1986 VL Calais Turbo, VZ SV6
Have you been pumping your 90's commodore with expensive 98 octane? if i had been i would be calling bull **** to because i hate wasting money.
Robbo VS3
33
In The Sticks NSW
VE SSV PHANTOM
Just wondering guys, if someone is running standard 91 octane in their vehicle and they want to switch to 95 or 98 octane can you just chuck that on top of the 91 octane, like does it matter if they mix together, or do you need to drain your tank?
My Ute is a V6 Ecotec and i think i remember reading in the manuel that it is tuned to run 91 octane, so thats all i have ever used. However, i have a performance memcal now, and i may need to use 95 or 98 octane with it, or i may benefit anyway.
wraith
Demonicaland
My Ute is a V6 Ecotec and i think i remember reading in the manuel that it is tuned to run 91 octane, so thats all i have ever used. However, i have a performance memcal on the way, and i may need to use 95 or 98 octane with it, or i may benefit anyway.
It doesn't matter if they mix. Just remember it will take a couple of tanks before it's pure 98.
Ozzie
JCCC Warrnambool
Warrnambool
Nah ur good to go. I usually in these circumstances (having a 98ron chip) use a bottle of nulon race formula octane boost if i cant find anything but standard unleaded.
Depending on the tune, My car runs like **** on 91, okish on 95 but smooth on 98
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
I can only go off personal experience which is by no means scientific. But when I run 98 I get 600 km's to a tank on anything else it's 400 km's. Although I suspect my car is tuned for 98 already as it refuses to run properly on anything else.
Wraith
Your claims are not credible. You are telling us that your 94 Buick engined VR increases its fuel economy by 50% just by using premium unleaded?
Unless your engine has a much higher compression ratio than standard, or is supercharged, (in which case your economy would go the other way), I can't see any way it's "tuned for 98 already."
But, it's your story and you're entitled to believe it.
