high oil pressure wtf?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pow3rslave, Jan 30, 2007.
  1. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    just a query, i've got pretty high oil pressure at idle lately, up to 90 psi and bouncy, less when driving (that figure hasn't raised from what it was) but is this anything to be concerned over?
  2. defa
    defa New Member
    VN Commodore
    that seems a little odd. is it an electric gauge??
  3. pow3rslave
    eastern subs, vic
    VP 5.0L
    yeah, could just be goin nuts, seems to do it more after startup, which i'd have thought would be the time for low oil pressure.
    doesn't do it all the time though.
  4. defa
    defa New Member
    VN Commodore
    when the oil is cold it will be hihger. but i still didn't think that high
  5. immortality
    Sth Auck, NZ
    the pressure bypass spring in the pump should never let it get that high, hot or cold even when it's revving it's nuts off. maybe you got a bad earth somewhere forthe guage or the sender unit etc
  6. pow3rslave
    eastern subs, vic
    VP 5.0L
    is a dud pressure bypass spring a possible culprit?
  7. immortality
    Sth Auck, NZ
    when the pressure bypass spring weakens it normaly looses a little pressure. it would be impossible under normal circumstances for an oilpump to produce 90psi of presure at idle i'm pretty sure. the only we to be certain would be to fit a T piece and plumb in a mechanical pressure guage temporarily to check the actual pressures etc
