High output alternator (250+ Amps)
Discussion in 'VF Holden Commodore (2013 - 2017)' started by KLoNe, Aug 26, 2018.
  1. KLoNe
    KLoNe Member
    6.2L V8 Phantom VF2 Calais-V
    Hey guys,
    I'll be installing a full SQ audio system in my VF2 next year so I'll be needing to upgrade the alternator.
    Closest thing I've found are Corvette alts for the LS3 (nothing available for the Chevy SS):
    https://www.dcpowerinc.com/fit/Chevrolet~Corvette~2012~6.2L-LS3-V8/13968-270-xp.html
    http://www.mechman.com/alternators/...g-alternator-for-c6-corvette-machined-finish/
    Am I guessing these may be compatible because they use the same engine, or am I completely missing something?
  2. LodiBruce
    LodiBruce Member
    Linden, California USA
    2015 Chevy SS Sedan
    Hum... Well, you need the correct frame size along with the correct connector and charge wire location. Clocking can be achieved easily, so that's not a big issue. B.
    KLoNe likes this.
  3. LodiBruce
    LodiBruce Member
    2015 Chevy SS Sedan
    KLoNe likes this.
  4. KLoNe
    KLoNe Member
    Wow, that looks great - thanks for your help LodiBruce, exactly what I was after!
    Edit: Hmmm, finding some bad reviews on bnrparts alternators from a quick search, but will continue investigating.
  5. LodiBruce
    LodiBruce Member
    2015 Chevy SS Sedan
    Yep. You can also rebuild your alternator with higher output components. They are easy to do. I think our alternators are AD230/AD244 series. Trying to confirm that. As soon as I do I will post a link to a very reputable company you can buy the parts from. Or new alternators as well. B.
  6. KLoNe
    KLoNe Member
    I've spoken with the staff from JS Alternators and they have the following available:
    • 250amps - $359US
    • 320amps - $459US
    • 370amps - $559US
    I've also heard the brand Singer being mentioned so will look into them too.
  7. Banjo79
    Banjo79 Active Member
    VF SS Sportwagon
  8. KLoNe
    KLoNe Member
    Cheers banjo.
    My amplifiers will be producing 5kW RMS, so gonna need some decent grunt to keep the batts charged :oops:
  9. Banjo79
    VF SS Sportwagon
    Right. I was way off. You mentioned SQ, probably SPL would be more accurate. Are Commodores screwed together well enough for 5000w rms not to rip them apart? Helluva system, good luck.
  10. KLoNe
    KLoNe Member
    Hahaha, unfortunately I'm not sure how well the commodore will handle the output, but she'll be sound deadened to the best of my abilities.
    Most definitely a full SQ install - I have no time for SQL (but hey, we'd be lying if we said we didn't like your music loud sometimes :p).
    Here's my last install for reference and a preview of the gear to be used again (mostly the same):
  11. RWD4ever
    RWD4ever Member
    Gosnells
    VS3 ute
    Do those have bigger pulleys? When I worked in geophysics, we had 300 Amp alternator on the equipment truck, and it needed a big pulley
    (otherwise the drive belt would slip at full load) but then with the engine idling, the dash discharge light came on...
  12. Banjo79
    VF SS Sportwagon
    So how does one embarking on such a substantial audio upgrade calculate the alternator size required? Golden rule, stab in the dark, educated guess or all three?
  13. KLoNe
    KLoNe Member
    I use the dart throw method haha.
    Nah, quick maths is the key.
    Banjo79 likes this.
  14. Banjo79
    VF SS Sportwagon
    So a Commy is making a couple of thousand watts. Very roughly half chewed by the car. So a 1000wrms sub with a 4 x 150wrms amp or thereabouts would be safe at normal to loud volume but totally battery draining at full tilt? "God my stereo sounds bitchin, but why the hell is my steering so damn heavy said the VF driver to the VE passenger!"
  15. Banjo79
    VF SS Sportwagon
    Oversight. I failed to take into account at what RPM those couple o thousand watts are being made. So a 140amp alt is rated at what RPM to make those amps?
