high preformance lifters for an ecotec
nermal
mornington peninsula
wh v6 statesman
hi i was just wondering what are the choices in brand names for high performance lifters for an ecotec motor that are very reliable and can handle a lot of power
cheers.
chargedvx6
VY SII HBD Calais L67
Crow resell Morell lifters. I've heard there's nothing wrong with OEM lifters as long as they are set up right
Thomas1
34
Melbourne, VIC
VS L67 Statesman
Yep. As long as you aren't going for HUGE revs then use the stock lifters.
chargedvx6
I'm all for short shifting a stock bottom end L67. 5600rpm shifts FTW:yeah:
nermal
wh v6 statesman
im going to be putting a 4.2l stoker kit from come racing in a ecotec because i will be supercharging it later on and i heard that the "speed pro lifters" that come with the kit are not good so will be changing them to something better if there is better out there of course, the rev limiter will be getting reset to about 6300rpm, so year it not going to be stock engine.:thumbsup:
cheers.
HoldenManDan
Built, not bought...
Penrith, NSW
VS Exec SII 4.2L L67 T56 :D
i've got an L67 in bits ready for the come stroker to go in, and have heard the same about speed pro lifters, so i am also keen to get a different brand lifter put in. I called my engine builder to see what he could find out... apparently the speed pro lifters are only rated to 6000rpm, and something along the lines of a GM product being available for the v6, a "performance" lifter similar to LS1 lifters that are rated to 8000rpm. I only got sketchy details thus far, but when i find out more i'll post up here.
Anyone else got any additional info?
greenfoam
101
VP Executive R-spec
I don't think you will find a better lifter than the factory GM/Delco who ever makes their stuff
GTP 85
291 hp @ the wheels
Murray Bridge S.A
MY04 WRX, VS SSenator & VS V6 track weapon
i just have OEM lifters. Inspected them and put them back in. Did some research on lifters after choosing my cam grind, and an engine builder said the stockers (if in good cond) will do the job for your application.
Mine makes peak power at 6300 and the limiter is at 6500
LJS-UTE
Aspendale, VIC
VY6 Ute
As a few others have said, factory lifter are worth their weight in gold, alot of people get fooled into buying products they dont need because they under estimate the capabilities of alot of OEM parts.
As long as the mileage of the part doesnt rival most taxis, you should be laughin.
