Ok, well. I've got the car back after getting a changeover engine installed. It runs nicely now - however I'm having some issues with overheating. I can leave it idle for ages and the temp doesn't increase too much - I can even drive it around the local streets, but whenever I hit 80kph+ the temp climbs to between 1/2 and 3/4... as soon as I slow down again, the temps return to the lower 1/2 of the dial...
I replaced the thermostat today - no difference. It heats up quickly to around the normal temps, and sits there on idle. Only 80kph+ seems to get the heat going.
I've also noticed that the heater in the car doesn't seem to get very hot. I've checked the vacuum operated heater tap and that seems to be operating as it should (ie the switch opens and closes) although I had to fix this - the cutoff wasn't working properly at the start.
Any suggestions on this? I would assume that when they replaced the motor that they would have done a flush etc...
