high ratio roller rockers or cam?
HuskeyVR
Alaska
NONE
hey guys, I've got a 94 vr berlina, 2nd stage shift kit (auto), sports exhaust soon to have CIA.
i was wondering which would be better to get performance and cost wise. either a bigger cam or high ratio roller rockers, also as far as i can tell they do the same thing... let more air in longer... correct me if im wrong (most probably am)
STL17
Whipit
townsville
Raptor charged vp v6 manual
Rockers are best bang for buck unless u know how to pull engines down and install cam
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
Rubbish.
Cam in every way shape and form.
Rockers are the dodgy way of doing it. Nice way to screw up the valve train geometry.
Rhin0o8
VZ Calais Impounded?
You build a house from the foundation up, why not do the same with an engine.
Go for the cam
HamaTime™
VIP Member
C Class AMG
Do things properly. higher lift Cam, and if necessary, lighter stronger ROLLER rockers to suit combo. Pair them with the camshaft.
soop
Banned
Smithton, Tasmania.
Standard ratio rockers are the go.
Problem with the V6 is the low static compression. Limits the choices with cam's.
GTP 85
291 hp @ the wheels
35
Murray Bridge S.A
MY04 WRX, VS SSenator & VS V6 track weapon
Years ago i started with RR's. not one of the best decisions i made, but still made some gains. Later went for a bigger cam and wished i did it in the first place
Therefore im with some of the guys above.... chuck a cam in there... dont be shy either, put something reasonable in there
Blakvsexec
5.0L VS EXECUTIVE
Have a look at the range of cams here, these guys been making more horsepower from the same v6 engines for longer than us.
ZZ Performance
HuskeyVR
Alaska
NONE
yeah i wouldnd be putting anything pissy in there, definatly lumpy lol
thanks guys, pretty sure ill be getting a cam now
