High speed fan
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Colin Lovegrove, Oct 27, 2019.
  1. Colin Lovegrove
    Colin Lovegrove New Member
    Dudley park
    Vt commodore series ll
    Hi my high speed fan cuts in for a couple of seconds when i turn air con off but doesnt come on when supose to ive checked fuses relays ran wire from fan to batt all good can some one help pls
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Maybe the engine is not getting hot enough for the high speed fan to turn on. The high speed fan always come on when the A/C is turned on regardless of temperature.
  3. Colin Lovegrove
    Dudley park
    Hi mate yeah it doesnt even do that the low speed fan comes on when i turn air con on and when i turn it off and it clicks the high speed fan does a couple of turns
  4. Colin Lovegrove
    Dudley park
    Ive had it running hot to much for the low speed to handle because my rpms from idle drops like its going to stall
  5. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    I thought only the low speed fan comes on when you turn the A/C on and once the temp is about 111deg the high speed comes on then switches off at 109deg. Without A/C on low fan should come on at 104deg then off at 99deg.
    Colin Lovegrove likes this.
