highbeam not working but lowbeam/parkers are
simma
pyramid
vs commodore
Hi all!
just wondering if anyone could help me out with why my highbeam isnt working? checked fuses, replaced globes etc
parkers and lowbeam work fine i just have no highbeam..
Big-Al
Banned
Aussie and proud
VY SS 5.7 M6
check the relay isn't stuffed. I believe there is a separate one for hi beams
ephect
Donating Member
VS Acclaim V6
^^^ this
Swap the hi and low relays and see if the issue follows the relay or remains the same..
simma
pyramid
vs commodore
thanks will check it and let you know how i go
simma
pyramid
vs commodore
Swapped the relays but still doesn't work. All fuses are good & put new bulbs in, still no go..
greenacc
Searching for the billion
VE Berlina
it's possible the switch is stuffed ( then you would need a complete indicator stalk for around 70 bucks )
Do hazard lights work ?
ephect
Donating Member
VS Acclaim V6
As above, the indicator stalk or maybe the lights switch. Do U have someone U can do a swap with to test the light switch? Id say rule that out without spending cash. If that fails next inline to fail is the wiring in the stalk
yoshi87
south australia
vs commodore
have u thought bout the light ontop under the cover of the headlights as that is a seperate light, check that and go from there
Marco59
64
Queensland
vs sv6
Try taking the globe out and place it on a metal part of the body to make sure its earthing
