hissing noise
Timmos
Kellyville
forums.justcommodores.com.au
10' VE SSV
Gday all.
I've noticed a noise coming from my engine, Sounds exactly the same as if i've taken the airbox out. My car has also been idoling funny latey, will sit at 1500rpm on idol and then randomly drop to 500 and hover between 500 and 1000.
One of my mates suggested something may be blocking the maf sensor. So i took it off and had a look. Nothing seemed to be blocking it. When i started the engine without the MAF sensor, the hissing was 20x louder and i could feel hot air blowing out of the intake. Is this normal?
Oh and i should mension i got a check engine warning today. but the next time i started up it went away. Oh and incase it matters. I'm running LPG. dual fuel system
any ideas?
Tiger28
Vy Exec
Hi Buddy I put my car on lpg about 2 months ago and what I notice is that sometimes when the car is cold when I start up and drive it makes a sucking noise like hissing ,but when it warms up it goes away.I have been getting check engine light to now sometimes and as like you it goes away.I took it to my Mechanic and he put the computer and plugged in to the bottom of steering to see for any faults and nothing read and all was fine.He then checked the lpg system and said similar nothing wrong.Was told maybe could be O2 sensors but he told me all is fine.Light still comes on now and then.
Timmos
Kellyville
10' VE SSV
Hey mate, cheers for the reply. Only thing i've noticed that's different to yours is mine never goes away. I've had LPG for almost 10,000kms so i'll go for a service and see what i they say i guess
cheers
batty_123
2003 VY
ive got lpg dual system on my VY aswell.. but mine doesnt do this?
whitey66
VY S Sedan
Did you check the little rubber vacuum elbow at the bottom of the throttle body?
The plastic hose that goes to the purge solenoid often comes off the rubber elbow and sucks air.
If it has come out,just put some super glue on it and refit it.
sp001in
vyma100
QLD
VY ute
Not sure about the VY but my Vq used to do this. the IACV (Idle Air control Valve) on the throttle body had some dirt in around the seal, and wouldnt always shut properly. Airbox or not the thing sounded like a jet engine, cos it creats a whistle through the airfilter plumbing.
Remove it, clean it with throttle body cleaner and see if it makes a difference.
Timmos
Kellyville
10' VE SSV
Thanks for the comment! but any chance you'd have a pic of this, I'm just not mechanically skilled enough to know what that is :p
sp001in - thanks, i took off the IACV and cleaned it with throttle body cleaner. Definantly looked a bit average. but i've still got the noise. Although my idoling appears to have gotten better!
Timmos
Kellyville
10' VE SSV
Ok, i found the rubber elbow at the bottom of the throttle body and yes the tube that connects to the purge solenoid has come off.
Where is the purge solenoid? I've tried to google it and cannot find a picture of it.
Thanks
trentvy
Dodges raindrops
Kilsyth South
Vy S pack
hey mate same problem with mine only the tube that connects to my elbow is only slightly comming off not completely off. whats a good way to get it back on??
