Hit a gutter in my 2007 ve ss
Leonard scully
52
Ve ss 2007
Hi all i was drivng in heavy rain last week going to turn a corner and lost control front left tyer hit the gutter going about 40 k broke the tyer rod was able to drive it home everything was all good start it up every 2 days to keep the battery from going flat why i wait too get it into the mechanic any how started it up to do the engine light stayed on instead of going away when it goes through the start up sequence on the dash im just guessing it mite be the power streering any and put would be appreciated thanks
lout
60
Langwarrin Victoria
you lost control at 40 km/h?
you drove it with a broken tie rod end?
if this post is genuine me thinks you need to get a mechanic come to your house and then a driving instructor
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
School holidays brings them out.
redvxr8clubby
Sunshine Coast QLD
VX Clubsport R8 & VE SS
If you have check engine light on you need to get codes read. Once the suspension is sorted, you could try Supercheap, they'll read codes for not a lot of money, need to make an appointment for this. First I was thinking ABS sensor, but you said check engine light not ABS light. You could try disconnecting the battery for a while then reconnecting and see if the light is persistent and recurring, if it is, getting the codes read would be best way to go.
scaredyet
Mosman
Holden VZ Lumina Wagon
Maybe attach the machine to your ears and tell us all what it comes up with
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
I'm trying to work out how you can drive with a broken tie rod. Or how you can be stupid enough to even try to do so.
gossie
Gold Coast.
VE International 3.6L
Has to be a school kid about 6 or 7 years of age is my guess. Still a baby brain.
Can't spell, or put words together properly, let alone type.
Probably heard the word "tie rod" from somewhere and the baby mind decided to use it.
GET OFF YOUR MOTHERS/FATHERS COMPUTER BEFORE THEY CATCH YOU LOOKING UP STUFF THAT'S FOR GROWN UP PEOPLE.
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
This thread appears to be a load of...…………..
Calaber
Aww, fellas, you're being a bit harsh. He's not a 6 year old, he's a 46 year old. I thought by the time you reached that age, public wanking was in your past.
wetwork65
A wet business
46 and on school holidays as I said above. Must be a school teacher?.
