Hiya!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by yZoH, Sep 29, 2006.
  1. yZoH
    S/E Subs, Melb
    (0.o')
    lol hey guys, thought i'd say hi... I'll be here alot from now on i guess..... Concidering I'll have an ecotec in my vn now.
    hehe
    MaT
  2. SlyVR
    SlyVR Fo'sizzle....
    VR Wags
  3. WILD VR CLUBBY
    WILD VR CLUBBY lack of licence
    Melborne
    2004 vy s
    hows the eco tech goin was it worth the conversion coz i wanted to goto a alloytech in the future when there a lil cheaper
  4. sixshooter
    sixshooter New Member
    2x VS
    Hmmm upgrades ? Have you got boost ?:dance::w00t: :bow:
  5. Patrio7
    Patrio7 3Y3 K4N 5P33K 1337.
    Perth, Como
    '96 S1 VS Exec
    heh an ecotech in a VN should fly nicely, wonder if it is coupleable with a VX tranny, shift kit that and it should fly lmao
  6. jc58nc
    jc58nc Guest
    I,ve fitted a Vx Ecotec and Vx auto into my Vr ute, so yes the tranny will fit.
    It's a lot of work but I think it's worth it.
  7. yZoH
    S/E Subs, Melb
    (0.o')
    I'm going mechanical TH700 from my VN with stage 2 shift kit
    VS Ecotec motor with VT Super6 injectors
    Re-tune on the VN Memcal using VN ECU
    Disabling Sequential injections
    Using a MAP sensor instead of a MAF sensor
    Should be at the 120rwkw mark
    And within 6 months' she'll have full exhaust/extractors
    130rwkw mark
    and within a year an m90 top end
    170-200rwkw mark
    MaT
  8. Murdoch
    Murdoch Active Member
    VF II SSV Wagoon
    Don't know whether you will get 120rwkw mark with just the first mods mentioned.
    manual ecotecs with exhaust, extractors, rockers and every other mod get around 125rwkw.
  9. stylin_vr2
    stylin_vr2 New Member
    hoppers, melb
    BF fairmont (when im allowed)
    pwoar... ok so when uve done it all... can i drive it?? lol :driving:
    i'll be your friend..:thumbsup:
  10. yZoH
    S/E Subs, Melb
    (0.o')
    Big difference between Map & Maf sensor setups mate.
    MaT
  11. Murdoch
    VF II SSV Wagoon
    Yeh true.
    I guess the ecotec heads breathe a lot better than the buick haeds, so your power isn't limited there. I initailly failed to see that you now have an ecotec motor in :bang:
    Keep us posted on the progress. If your succesful with that sort of power output i would imagine that there you would generate a fair bit of interest in ecotecs running a MAP.
  12. immortality
    Sth Auck, NZ
    good to see you here, the ecotec should rock with the MAP sensor intsead of the MAF. there's a good reason all the LS1 guys are doing it. looking forward to hearing some ofthe results
  13. immortality
    Sth Auck, NZ
    good to see you here, the ecotec should rock with the MAP sensor intsead of the MAF. there's a good reason all the LS1 guys are doing it. looking forward to hearing some ofthe results. go the Mighty VN:yeah:
  14. sixshooter
    2x VS
    Hey Hozy, You'll need a lot more than 8 PSI boost to crack 200 RwKW...(266 RwHP). Ecotec pistons are the weak link...any detonation with boost and you'll blow their tops to pieces...you better budget a tough bottom end build up into the plan with forged pistons if you want the engine to last a few years ! GL with your build !
  15. AirStrike
    91' VN SS
    No need for L67 injectors matt, wont be making enough power to max out the stockers.
    AirStrike :air:
