hmmm. need help
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by jason_85, Jan 21, 2012.
  1. jason_85
    jason_85 New Member
    Wodonga
    02 Vy SS and 99 Vt SS
    hey all.... yesterdeay i cleaned out my throttle body on my vt v6. i also cleaned out the air box and pipe. took the air flow meter thing apart and cleaned it too as it was completely filthy.... just took it for a drive and now the engine light comes on and off, sometimes idles at what id say is 500rpm ( the first line above 0) and holds second longer than normal and slams into gear..... what did i do to stuff it up??
    thanks in advance..
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    How did you clean the air flow meter? They a pretty sensitive. Best thing to do is check the error codes and that should point you in the right direction. Sounds like it could be the throttle position sensor.
  3. FstStig
    FstStig Diagnostician
    Central Coast, NSW
    2010 VE SV6
    Slamming into gears sounds like your TPS (Throttle position sensor). What was used to clean your throttle body? It has been said not to use Throttle body and carby cleaner on the senors as there is a high chance of stuffing them.
  4. jason_85
    jason_85 New Member
    Wodonga
    just cleamed it gently with a toothbrush... just got the gunk off the alloy things and put it back together... nothing broke of anything. made sure of that..
  5. accentstencil
    Eschol Park, Sydney
  6. jason_85
    jason_85 New Member
    Wodonga
    Everything is fine now... The little wires went wrapped around the prongs properly in the air meter. Rhey are now and the car is running fine. cheers fellas
  7. jason_85
    jason_85 New Member
    Wodonga
    Checked codes and got nothing but 12...
