Holden 3.8lt Turbo or S/C??
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Frandy, Oct 13, 2005.
  1. Frandy
    Frandy _____________
    Diamond Creek Melbourne
    '14 VF SS-V M6 / '99 KN Laser
    Hey guys,
    I was just wondering wat is the trend with Holden 3.8lts. What is more bang for buck and which is more popular, Turbo or S/C? :w00t:
    I lyk the turbo more, but thats just cause of the awesome sound from the blow-off :yeah:
    Cheerz
  2. darktele
    darktele Guest
    I dunno what is most popular tho i would say the Superchargers is.. I have not seen a VY turbo as of yet. but if anyone sees or owns a turbo vy i would be interested in the specs and cost of full set up as i'm looking to do somthink turbo to my 3.8ltr vy :p Ecotec engine.
  3. AlX
    AlX New Member
    VY 2004 Calais II
    Tur80
    I think Holden engines or even american build engines get more power out or S/C. :unsure: like mercedes which is Compressor=Supercharged.
  4. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    i know that C.A.P.A has just released something for the alloytechs because they have just slapped one into a vz sv6 in the workshop at berri :D saw the drift ute there too hehe :p
  5. gen3_350_v8
    gen3_350_v8 New Member
    ss vy 5.7l M6
    id have to say if a gen3 go twin turbo if you have the $$$$ more kw/$ with turbos on high boost and intercooled, even a v6 with benifit from a bi turbo setup, but if your low on cash go the supercharged way, my 2 cents
  6. Frandy
    OK guys, i have another question....what is more bang for buck, or which one is most sensible to go with??
  7. maxy0987
    maxy0987 New Member
    VY Exec S2
    id say S/C, dont know why but i do, just have the feelign they would be less hassle after reading around and seeign what happens when peopel try to twin turbo and need to replace all sorts of stuff
  8. familyguy
    familyguy Bog Standard
    Northern Beaches, Sydney
    VY Executive S2
    You'd have to figure the supercharging option is easier, knowing that Holden already fit them to the Ecotech in certain vehicles. I could be talking out my a#se, but isnt the VT andonwards S-model a supercharged Ecotech? (Any internal work done on these or is it just a bolt on and reconfig ECU?)
    The turbo is probably a dicier option, but FIT and CAPA both do a turbo I believe.
  9. VT-565
    VT-565 New Member
    QLD
    VT
    common misconception #459 - a supercharger uses a blow off valve too, depending on the type of blower system installed :king:
  10. SPack
    SPack Wish it would rain......
    Oakey, QLD
    VE MY10 SV6 sportwagon (phantom)
  11. irws85
    irws85 New Member
    Bundy
    VS Commodore
    Well, supercharger is cheaper, but turbo will get a bigger bang.
    looking at bout $20,000 you could have your ecotec a good rival against any worked v8
    i'm talking 440 RW HP/ 330 RW KW from just a GT30 setup
    thats talkin 0km-100km in 4seconds
    of cause with a good stall converter etc etc
    but 4sec's from a V6 think about it, the new 6L 297kw V8 HSV R8 only does it in 5.1 seconds!
    you can do it for bout $14,000
    but if your gonna do it, do it right the first time and upgrade the things that are gonna go, e.g, diff, gear box, tail shaft, brakes, and take your motor to an engineering company, and have it modified to handle the compression of a Turbo application, Face it otherwise your just gonna keep blowing it up!!
    Even VL boys have that problem, rebuild an RB30 chuck the turbo on, bye bye pistons and con rods, yet buy a second hand motor from the wreckers, turbo it and drives a real treat!
  12. maxy0987
    maxy0987 New Member
    VY Exec S2
    i somehow dont think frandy needs a car that can do 0-100 in 4secs :p
    And not for 20,000 (thats the value of my car lol)
  13. Frandy
    Never know, 4 seconds ey?? Sounds lyk fun :yeah:
  14. SUPERV6
    SUPERV6 SUPERV6 13.299@101.44
    Moonta (SA)
    VT 'S' Supercharged V6
    The only things basically common to the L67 (Super6) and the L36 (Ecotec) is the block, sump, rockers, pushrods and oil pump. Everything else internal is different (pistons, rods, bal shaft, heads etc). Check this FILE for more details. Plus you only get factory auto trans behind a L67.
    Oh and VS was the first model fitted with the L67 ;)
  15. giannetto
    giannetto New Member
    Black vy 'S'
    How much roughyl for everything involved with a small single turbo setup
