Holden 308
Holden 308
53
Hervey Bay
Holden 308 hq
Holden 308 flat top pistons protrude deck 084 this going to be a issue
EYY
VS Statesman
You need to select the correct pistons, rods and crank for your application. 304 and 308 cranks give different stroke. You'll need to select the correct pistons with the pin height you need.
Immortality
Staff member
Sth Auck, NZ
Yep, as above, you have used the wrong piston and/or rod/crank combination. 308 and 304 have a slightly different stroke and different piston pin height to achieve the proper compression height with the same block deck height.
gtrboyy
vt ss & lc gtr
Yep my thoughts too wrong pistons for crank or vice versa.
Holden 308
53
Hervey Bay
Holden 308 hq
Yep just measured conrods i have 5.700 and the ol ones 5.625 grrrr
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
