[General] Holden Commodore/Statesman Service Lamp Re-set Procedures VT-VE
Discussion in 'Holden Commodore How-To's' started by ben315vz, Nov 17, 2011.
  1. ben315vz
    ben315vz Donating Member
    Tamborine Mountain, QLD
    '05 Holden VZ Calais V8
    Hey everyone.
    Thought that I would do a write up on the service lamp re-set procedures.
    This write up will cover VT/VX/VU/VY/VZ/VE Commodores and WH/WK/WL/WM Statesman/Caprice.
    VT/VX/VU/WH Series.
    1. With the ignition OFF, press and hold the up and down buttons of the Trip Computer.
    2. Turn the ignition ON while holding down both buttons.
    3. Keep both buttons held in for 3 seconds approx. and then release both buttons.
    4. Press and release the 'Mode' button (The service due screen appears on the display).
    5. Press and hold both the up and down buttons for 3 seconds approx. until a beep is heard.
    6. Release both buttons.
    7. Switch ignition OFF.
    VY/WK Series.
    3. Keep both buttons held in for 3 seconds approx..
    4. The service menu appears and asks if you want to reset.
    5. Press and hold the 'Set' button for more than 3 seconds.
    6. Press the "Mode" button.
    7. Switch the ignition OFF.
    VZ/WL Series.
    4. Press and hold the 'Set' button for more than 3 seconds or until an audible alarm is heard.
    5. The display shows - SERVICE RESET NO ITEMS.
    6. Press and hold the 'Set' button for more than 3 seconds - the SERVICE OIL LAMP will extinguish.
    7. Turn the ignition OFFm then ON again.
    VE/WM Series.
    1. Switch ignition OFF.
    2. Press and hold the 'Trip' button.
    3. Switch ignition ON.
    4. Release the 'Trip' button to enter the Service Reset Screen.
    5. Once in the Service Reset Screen, press and hold the 'Enter' switch for 3 to 5 seconds (a beep will sound as confirmation of reset).
    6. Switch ignition OFF.
    7. Should the service reminder come back on when the vehicle starts, repeat the procedure.
    NOTE!
    Should the service be overdue, the Multi Function Display will show a flashing icon for up to 10 seconds whenever the ignition is switched on or off (this will continue until the Service Reminder Reset Procedure is carried out).
    Should the service be overdue for more than 5,000 km, the event will be permanently logged in the Instrument Cluster memory.
    Took me some time to write this up so I hope this information helps :)
    jimmyw likes this.
  2. ben315vz
    Just a suggestion, but could the mods make this a sticky? As it covers the whole range of Commodore/Statesman that came out with a service lamp. I will also keep it updated in the future when newer Commodores are released and have different procedures so its all on one thread.
    Cheers,
    Ben
  3. ben315vz
    Has this thread helped anyone yet?
  4. aaronevolution
    aaronevolution Donating Member
    Hastings, Victoria
    TURISMO VZ SS 6.0
    It will tomorrow when I reset mine.
  5. Scream
    Scream New Member
    VE 08
    Worked a treat on my VE, cheers mate.
  6. VS_Pete
    I saved it to favorites and will use.
    Once you reset it won`t come back on till next service due?
  7. ben315vz
    Thats correct mate.
    The service reminder appears 1000kms before the service is due, and then stays on until it has been reset.
    Example.
    If your car is coming up to the 150,000km service, the service reminder will come up at 149,000kms.
    I noticed with my WH Statesman, the service reminder comes up, and once you go over say 150,000kms, the service reminder starts flashing.
  8. VS_Pete
    Thanks for that.
    I said I was going to annoy **** out of everybody when the new car comes lol.
  9. jamesmp
    jamesmp The Photo Journalist
    Sydney, NSW
    MY12 VE Commodore SS
    Worked perfectly! Thanks for this!
  10. stevenroar
    stevenroar New Member
    2006 VE Omega / Look-a-like SSV
    Worked perfectly this morning on my VE thanks bud!
  11. Mark24
    Mark24 New Member
    Central Coast NSW
    VE Sportswagon
    mine was flashing a reminder at 75,000 k's still there at 124,000 just tried the reset and it worked fine, thanks for the information, dealer never reset it and I have serviced it ever since and now finaly it's gone :)
  12. ben315vz
    Glad this thread has helped some people :) I thought it was a good idea to make one thread covering all models.
  13. Bezzey
    Bezzey New Member
    Brisbane, Australia
    VT 99' Series II
    Will reset mine this morning thanks man.
  14. atomant
    atomant New Member
    rockhampton
    vx berlina
    worked great thanks
  15. redhotss07
    redhotss07 New Member
    Inverell
    '07 VE SS ute
    Very good,done,Thank's.
  16. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    I've found on the VZ if the car had an error code stored in memory the service reminder will not reset until the codes are cleared.
    Anyone else find this?
  17. 67wogval
    67wogval New Member
    west suburbs, melb
    vz commodore
    I'm having trouble getting the service vehicle soon of on my dash on my vz, the steps described here doesn't seem to be working, I have tried a few times and I can't get it to work, can you clarify the exact steps as to what to do again please, as I think I might be getting confused between steps 3 and 4....do I keep the up and down arrows held in when holding down the set button once ignition is turned on?
  18. ben315vz
    Not sure how it could be explained more clearly. And yes you have to hold the up and down buttons on as you turn the ignition on.
  19. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    I tried it for my friends vz, but didn't reset it, so that means they have an error to be datalogged and cleared before it can be reset?
  20. ben315vz
    Did you try it more then once?
