Holden commodore sv6
Greenholdensv62006
Alice Springs Northern Territory
Holden commodore ve sv6
my car can’t start or crank everything ok fuse and the battery still new , it’s just I accidentally touched the ground iron while I was trying to change the battery while the car was still on. Then it sparked and then I tried turning it on again nothing happened could not start or anything please someone help
Fu Manchu
WA.
Holy ****!!!!
ALWAYS CONNECT NEGATIVE LAST.
DISCONNECT NEGATIVE FIRST.
You hopefully will need to replace the fusible links on the battery terminal. Now if you are really lucky that fixes the problem. However, that sort of thing can cook modules in the car. They talk to each other across a network called a CANbus network. Your car is a computer network on wheels. Finding faults in those is where the butt hurt starts.
Fu Manchu
WA.
Wait, you had the car running and changed the battery!???
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
You can’t help stupid. Probably ended up frying all the computer modules in the car by changing the battery while the car was running. I would say it’s a well deserved result but the Commodore doesn’t deserve to die because of its owner’s stupidity.
the_boozer
no more VK
51
Shitsville Morwell
hilux
Why would you do that what were you trying to achieve? Which ******** taught you to do that ? Why so you didn't have to rest the clock? its gunna cost you now.
Fu Manchu
WA.
If the engine was running or ignition on, you may have electronically written off the car depending on its insured value.
Again, best outcome is the fusible link is blown and you have a good day.
