Holden ve egr temp sensor please help
35
Waipu
2008 holden ve omega
My car had metallic ping and engine was moving around like missfire. So I changed spark plugs and intake manifold gasket and all the air lines to the intake as they broke trying to take them off. Pain persists after that and I got advice that it may be the egr temp sensor , which makes sense as my transmission is fine but keeps blowing solenoids cos it's too hot under there due to the temp sensor. Problem is I dont know where to unplug the temp sensor as it disappears under the fire wall , anyone know were the connection for it is thanks
Subju
VE Clubsport Tourer
a
BowTie
Jindabyne
Vr vt
Yep. Disconnecting things to mask something doesn't really work well. Much better to fix the sensor if that's the issue.
35
Waipu
Find a mechanic and get them to plug it in and read the error code is probably your first step.
I have a diagnosis scanner now.
