ITEM: Holden VS UTE 1998
PRICE: 9500 ono
YEAR: 1998
SERIES: VSII UTE
ENGINE: 4.2L Turbo Stroker V6
TRANSMISSION: 5 Speed
COLOUR: Silver
EXTERIOR CONDITION: Not too bad besides bonnet
INTERIOR CONDITION: Good
TYRE CONDITION: Front 90% rear 50%
TYRE SIZE INCLUDING LOAD RATING: Example: Stock 15s
ODOMETER: 197xxx
SERVICE HISTORY: nope
REGO OF CAR: NSW
REGO TILL: JULY 2012
PLATES INCLUDED: Yes
DELIVERY/PICK UP INFORMATION: Pick up from Wollongong
PAYMENT OPTIONS: Cash when you pick it up
CONTACT DETAILS: PM or call or sms 0401909764 Ben.
OTHER INFO:
Gday guys, This is a bit of an EOI, if I get the right amount of money, it will be sold.
Its a 1998 Holden VS Commodore UTE, fitted with a Garrett T04B Turbo and a C.O.M.E. 4.2L stroker kit powered by a Microtech LT10s Computer. Now the ute you see in the photos was actually a repairable write off (fresh water damage from QLD floods) I bought it with minimal Interior and a buggered motor with an auto gearbox, the body is good and thats all I wanted it for. I also bought another statutory write off VS ute with all the good bit like motor and running gear all working perfectly, but the body was an absolute mess, it has a decent impact on the passenger side and the front was abit bent up, so I made the ute you see here out of these two. It is fully RTA engineered and has Rego till July 2012. Im a fully qualified Heavy Vehicle and Plant mechanic by trade, so all the work Ive put into this thing is pretty smick It also has about 197xxxKMS on the body its self, much less on the motor though.
First Ill list all the dramas, Ill be as honest as I can.
Passenger side manifold needs resealing.
Has a green bonnet
Cold start tune is off (runs perfect when warm)
Radiator crossmember is a touch bent, someone at the mechanics workshop thought it was a jacking point (Idiots). Wont take much at all to get it straightened out.
Interior fan control module leaks (vacuum operated) easy fix from wreckers
Oil pressure gauge reads wrong (cheap Supercheap Auto ****)
I know it looks like a fair bit but a weekends work (with plenty of time for beers) and she will be all sweet.
Now Majority of the good bits, Im sure Ill miss something, so ill add to it as I remember more
Bosch 044 external fuel pump, with alloy 1.5L surge tank mounted next to fuel tank, all hidden away
Stage 3 heads
H-Beam conrods
genuine Garrett CHRA T04B turbo center, come with receipt (had some **** cheap Chinese branded one in their)
Just had a service, fully synthetic oils used all round (engine, gearbox, diff) and all filters changed
washer bottle relocated to the rear (see photos) to make way for a POD type filter
Mace twin throttle bodies
3 inch mandrel bent Intercooler piping
Large front mount cooler, kinda hidden behind front bar.
3 inch Exhaust from turbo back, single muffler and a new high flow cat, sounds good not really loud.
Microtech LT10s aftermarket computer with hand controller and usb dongle.
Nice and tight LSD diff
New Kenwood CD player, with Bluetooth and iPod connectivity
Lowered on pedders springs and shocks all round
near new rear tyres
new brakes all round
done a VY brake front upgrade, with VT master cylinder, new rotors. Pulls up quick
Front sway bar fitted
New BOV
New plugs and Leads
6 month old battery
Oil overflow catch can setup
David Craigs fan temp controller
turbo beanie
exhaust all covered in engine bay by wrap and covers
engine has all the right bolt-ons for turbo setups like upgraded injectors, rising rate fuel regulators ect
Has a tow bar, never used it though.
Fully engineered buy RTA certified engineer.
Toyota Lexan seats, they look a little bogus but their so dam comfy.
Will put a smile on your face everytime you drive it
ITS DAMM QUICK. All motor work appears to be top notch, inspections are more than welcome. NO TEST PILOTS OR TYRE KICKERS.
any more questions, call me. Ben 0401909764. NO SWAPS UNLESS ITS FOR COLD HARD CASH
$8500
PICTURES:
PRICE: 9500 ono
YEAR: 1998
SERIES: VSII UTE
COLOUR: Silver
ODOMETER: 197xxx
REGO OF CAR: NSW
OTHER INFO:
Has a green bonnet
Stage 3 heads
H-Beam conrods
near new rear tyres
New BOV
New plugs and Leads
6 month old battery
turbo beanie
$8500
PICTURES:
