Holden vt acclaim low to lux bcm.
Zlimes
My Vt accliam lovely leds
30
Newcastle nsw
Holden vy commodore
hey guys im buying a lux bcm and everything,
just want to know is it a plug in and it will work?
holden 1998 Acclaim low to the lux/?
cheers needa know soon
Zlimes
30
Newcastle nsw
Holden vy commodore
Bcm Low to Lux!
hey i found a person that owns a holden vt, and hes wrecking it, and he has a lux bcm and computer, with the keyheads,
will it plug straight into my commy with a low bcm?
buying it tonight at 10 and want to know if it will
lout
60
Langwarrin Victoria
at the least the BCM and ECU will need to be linked with tech 2 or similar
as to whether it will plug in or operate correctly I would think so, but only a guess
sicksix
glenroy
vt 98 hsv clubsport
i think it might work but you might need the ignition changed over.and maybe the wiring loom it depends what he has in his car like if its an auto or manual .but i do know the key has to be coded to the ignition barrel and bcm youre old key wont work with the new bcm hope this helps
Brett_jjj
Tamworth NSW
vs commodore
With VT and later models, if you swap the BCM or ECU, you will have to relink the BCM and ECU with a suitable scantool or the vehicle wont start.. If you get the ECU as well as the BCM and keyfob(s) from the same vehicle it should be ok.
Zlimes
30
Newcastle nsw
Holden vy commodore
Hey guys with the Bcm I brought it doesn't have the
d plug connection in it
What do I do now?
I can send a photo to your phone if needed.
Just private message me your number.
Zlimes
30
Newcastle nsw
Holden vy commodore
Any one able to help me?
Zlimes
30
Newcastle nsw
Holden vy commodore
the bcm and that was out of a berlina ,? do u know if it work
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
If you look at the diagrams that I scanned from the Holden Service CD you will notice that the LOW, MID, LUX and Hi all appear identical to look at. According to the CD your car should have the Low 688 and for power windows you need the MID 686. I don't know why your car has a LOW 815, I looked on ebay and there seem to be a few 815 BCMs that they say are from a VT. It's a bit confusing. Is there anywhere on your LUX BCM that the D plug will fit, maybe on the side?
Fabled
24
SA
VT S S2, WK Statesman, VS Ute, VX Executive 1PC
Thread dig for days
