Holden VZ SV6 windscreen wipers not turning off
abzz
Commodore VZ SV6 3.6 A5 Turismo
Hi guys,
I have had this unusual issue occur with me 3 times within a 3 year time period of owning my SV6 so far.
For no apparent reason, when driving in rainy conditions, it seems as though I can't turn off my wipers when it stops raining, the only way I have managed to stop them is pull out the wiper fuse while driving.
The first time it occurred, it seemed to have fixed itself after a couple of hours, second time it happened it was fixed after 2 days, but now it has been occurring for the past 4 hours and has not been fixed yet.
I have replaced the wiper stalk with 2 other different stalks, but made no difference.
Anybody seem to know what is causing this weird issue?????
jeepyrocks
BMW 535D, VR V6 Ute
First things first- swap the wiper relay under the bonnet with one of the others and see if that solves it.
abzz
Ok, I will try, but so far it has automatically started working fine again, I would have no idea when it can occur.
Fu Manchu
WA.
Mate! Stop using the wipers when indicating at intersections.
Yep. Glad to be of help.
morley46
77
Tauranga NZ
VZ Crewman. 1978 HZ Statesman.
That's interesting, my VZ doesn't have a wiper relay under the bonnet (not in the main Fuse holder box anyway), where would i find it?
Fu Manchu
WA.
vz-wiper-relay.299799
It's powered by the accessory control relay in the fuse panel under the steering wheel.
I take it your horn, radio etc all work fine?
Have you removed the wiper cowl to inspect the wiper motor and its wiring harness that comes through from the engine bay?
Fu Manchu
WA.
Use the attached files to sort it.
There is too much to be able to write out.
Follow the diagnostic flow chart.
I'd say you have covered most of the prelim tests.
Inspect the column wiring for any obvious damage after the switch plug.
  • wiper diag.pdf
  • Wiper prelim test.pdf
morley46
77
Tauranga NZ
Aha, the accessory control relay, that narrows it down, will have a check of that before i try to get into the BCM, thanks again.
Fu Manchu
WA.
The only thing the relay in the BCM does is control the intermittent function of 8 seconds.
If you have an issue with not being able to switch it off, you need to go through the diagnostic flow chart provided in the two pdf’s I posted.
Going into the BCM chasing a hunch isn’t going to yield great outcomes.
Flow the diagnostic flow chart.
My hunch is a stuffed wiper motor but that can only be proven by following the diagnostic flow chart provided.
