Holden wb ute fuel sender lock ring
Holden050
54
Wb
Hey there
I need to clean/ replace the sender unit in the tank. The tank is still installed the ute and has a bit of old stale fuel in it
Whats the best method to remove the lock ring on the sender?
Was there a tool used to install/ uninstall back in the day?
07GTS
Australia
VEGTS BUILT BLOWN E85
just use a 5-6mm punch and hammer and tap the ring undone little bit each side so it undoes central wise, then when u re install it just make sure the ring stays center under the wedges to lock in
